This is how I replaced the door speakers aswell as adding speakers to the dash board
At the end of replacing speakers you will need to set the clock and date
I found the adaptors on ebay the seller is 7xm
Door speakers: Adaptor for speaker PEUGEOT,CITROEN - Peugeot 206
Dash speakers: Adaptor for speaker CITROEN BERLINGO , PEUGEOT tweeters
What you will need:
Speakers - I used Vibe SE K 60 speakers for the door and Vibe SE K 10 speakers for the dash (You can purchase speakers for the dash that twist in but these don't)
Speaker adaptors for door and dash (I found these on ebay the seller is 7xm)
Crimp connector butt
Tools needed:
Adjustable wrench
Torx T20 unscrew the door speakers
Wire cutters (Not to cut any of the original wiring)
A crimping tool
A flat head screw driver for lifting the dash grill
I also needed a phillips screwdriver for wiring the door speakers
These are the speakers I have fitted
[Image: Vibe_SE-K60new-450.jpg]
Step 1:
You must disconnect the Negative battery terminal to protect yourself and your car electricals
[Image: 1.jpg]
Leave this to the side
[Image: 2.jpg]
Step 2:
Remove the door speaker cover
[Image: 3.jpg]
Step 3:
Undo the 4 Torx screws and you may need to keep these so put them somewhere safe
[Image: 4.jpg]
[Image: 5.jpg]
Step 4:
Turn it over then disconnect the plug
[Image: 6.jpg]
[Image: 7.jpg]
Step 5:
Connect the door speaker plug to this speaker adaptor
[Image: 8.jpg]
[Image: 9.jpg]
Step 6:
Attach the ends of the speaker adaptor to the speaker (I used wire cutters to cut the adaptor crimp terminal off)
[Image: 10.jpg]
Step 7:
Put in the 4 screws I used the original screws
[Image: 11.jpg]
Step 8:
Prise off the speaker grill from the dash
[Image: 12.jpg]
[Image: 13.jpg]
Step 9:
Turn the speaker grill upside down and remove the cable from the socket
[Image: 14.jpg]
[Image: 15.jpg]
Step 10:
Use the Tweeter speaker adaptor to connect the speaker
[Image: 16.jpg]
Cut the adaptor terminals off and connect to the speaker with the crimp connector butt
[Image: 17.jpg]
Step 11:
Connect the speaker adaptor and plug together
[Image: 18.jpg]
Step 12:
I put small double sided pads on the bottom to stop it sliding around under the dash grill
[Image: 19.jpg]
[Image: 20.jpg]
Step 13:
Line up where the speaker should go as you can see in the picture there is a certain place the speaker goes under the grill
[Image: 21.jpg]
[Image: 14.jpg]
Step 14:
place the grill back over the speaker lining up the grill
[Image: 22.jpg]
Then push back down
[Image: 23.jpg]
[Image: 24.jpg]
Step 15:
Reconnect the Negative battery terminal
Pioneer sell speakers that fit a berlingo
http://www.pioneer.fr/uk/products/car_ac...index.html
What you will need:
Tools needed:
Adjustable wrench
A crimping tool
Step 1:
[Image: 1.jpg]
[Image: 2.jpg]
Step 2:
[Image: 3.jpg]
Step 3:
[Image: 4.jpg]
[Image: 5.jpg]
Step 4:
[Image: 6.jpg]
[Image: 7.jpg]
Step 5:
[Image: 8.jpg]
[Image: 9.jpg]
Step 6:
[Image: 10.jpg]
Step 7:
[Image: 11.jpg]
Step 8:
[Image: 12.jpg]
[Image: 13.jpg]
Step 9:
[Image: 14.jpg]
[Image: 15.jpg]
Step 10:
[Image: 16.jpg]
[Image: 17.jpg]
Step 11:
[Image: 18.jpg]
Step 12:
[Image: 19.jpg]
[Image: 20.jpg]
Step 13:
[Image: 21.jpg]
[Image: 14.jpg]
Step 14:
[Image: 22.jpg]
Then push back down
[Image: 23.jpg]
[Image: 24.jpg]
Step 15:
