  • 27 Vote(s) - 2.26 Average
rear brake hose change
Got a "sweaty" hose.
The brackets holding each end of the hose onto the body have little clips trapped by the pipe nut (I think).
Are these necessary - what purpose do they serve ?
I've managed to move most of the pipe connections, but I'm assuming the pipes will shear somewhere, so I probably end up changing both of these too.
So it will be all new from limiter valve down to the wheel cylinder.
'98 D 800 van Big Grin
ive just replaced the drivers side rear brake pipe and its copper pipe from the brake cylinder to the bracket wear the pipe meats the rubber flexie held in with a clip then its changes to copper pipe again to the load valve if that helps
get a life get a van !
You say copper pipe???
Probably copper coated steel pipe more like, don't think copper piping is legal for brake pipes as it is too soft!!!
na its defo copper pipe thats what i asked 4 when i got the pipe for makeing them and ive never had any trouble with them
Are you sure it is not what they call "Kunifer" pipe which is an alloy or mixture of copper, nickel and steel ????
Just done a "Google" and the jury is still out on this one....
Can i get away with 205/70r15
Last Post: bhcalcutta2
Yesterday 11:05 PM
Titsup
Last Post: Martinez
Yesterday 07:05 PM
Hello new member and warning light issues.
Last Post: Jamespworth
Yesterday 06:42 PM
Berlingo 2.0Hdi 2003 multi wont rev past 2000RPM
Last Post: peterbol
Yesterday 06:01 PM
starter motor issues
Last Post: mrnorth
Yesterday 04:49 PM
Steel wheels wanted
Yesterday 12:05 AM
Can’t find where to plug fault code reader in
Last Post: Martinez
18-04-2019 07:15 PM
Juddering when pulling away
Last Post: magoo
18-04-2019 05:17 PM
tyre wear
Last Post: my mucker
18-04-2019 02:49 PM
4x 15" Alloys with tyres
Last Post: Guanajuato
18-04-2019 12:46 PM
