  • 10 Vote(s) - 3.8 Average
Fitting New CD Player
I´m planning to fit the CD player I took out of my last car to the Berlingo. Is there anything to be careful of, or is it simply unplug old one & plug in new one?
I needed an adaptor to go between the Sony unit and the vehicle wiring - bought from Halfords, can't remember how much. Other than that it was straightforward, although the steering column remote doesn';t work with it, but not a problem
Hmmm................ nothing is ever straightforward for me!
I´ve found I need to swap a couple of live wires around on the plug so it works properly - no real problem.
But my clock freezes at whatever time it is when I switch the ignition on and stays that way until the next time I switch the ignition off then on again, at which point it changes to the current time and freezes again.
Any ideas???
1. Unplug the battery and plug it back in , stopped this problem for me
Or as grimsqueeker said
2. Take it to citroen to get the bsi to know the original stereo isn't there (this is the proper way and he said option 1 can eventually damage the bsi)
If you read some of the older threads on audio in the interior customisation then you can see what else has been mentioned on this topic
Lliam
70 plate Berlingo
[-] The following 1 user says Thank You to lemsworld for this post:
  • knobblywobbly
Thanks - disconnecting the battery seems to have done the trick
(29-04-2011, 07:14 PM)knobblywobbly Wrote:  Thanks - disconnecting the battery seems to have done the trick
is a good one for a lot of intermittent problems. Glad it's worked for you Smile
(29-04-2011, 01:40 PM)knobblywobbly Wrote:  Hmmm................ nothing is ever straightforward for me!
Any ideas???
i wire the switched live to the electric windows so it goes on and off on the key
and wired the permanent live to the battery to stop the freezing and losing stations
I have fitted new Kenwood head unit tonight. Took 20 minutes.
But mine loses saved stations.
Which wire will have to go straight to battery?
I am insured for FIRE and theft....
(29-04-2011, 08:19 PM)j90xxx Wrote:  I am insured for FIRE and theft....
Yeah, but who would nick a burning Berlingo anyway????
Can see a pall of grey smoke over Newcastle from where I live......oh no, tell me it isn't....
Thanks for coming so quickly...:eek:
Bumper with led
Last Post: Lingo09
Yesterday 05:54 PM
Amdro boot jump for sale
Last Post: Jaybee
Yesterday 04:41 PM
Paint advice
Last Post: Andhall
Yesterday 02:35 PM
Should I buy this van?
Last Post: Duggie12
25-03-2025 09:27 PM
sliding door panel removal
Last Post: mojito
25-03-2025 07:13 PM
Twin Cam Chain Snapped need some Parts Advice
Last Post: kingy1912
25-03-2025 01:10 PM
Rumbling Noise 55-65mph
25-03-2025 01:06 PM
XL tyres
25-03-2025 01:03 PM
Last Post: deejay_xb
23-03-2025 10:06 AM
» Replies: 32
Unusual Braking Problem
23-03-2025 07:57 AM
