  • 23 Vote(s) - 2.57 Average
1999 1.9D GLOW PLUG RELAY PROLEM
ANY ONE NO HOW 2 FIX THIS PROBLEM, GLOW PLUG RELAY KEEPS STICKING. SO NO LIGHT ON DASH, SO VAN NOT START, PUT NEW RELAY ON BUT STILL THE SAME, PLUGS ALL NEW. SOMETIMES IT WILL LIGHT UP ON DASH (GLOW PLUG SIGH), AND WILL START. ANY ONE HELP. THANKS CONRAD
should be starting in this weather without glowplugs, they are only needed when it's very cold
(30-04-2011, 07:15 PM)steve valentine Wrote:  should be starting in this weather without glowplugs, they are only needed when it's very cold
any idea why its doing this and how 2 fix it
Glad you found the caps lock key :thumbsup:
So could you describe the issue a bit more carefully?
The van doesnt start at all. Does it turn over?
Sometimes the coil light will appear on the dash and it will start?
Hi there,
If there's a multi wire plug going into the relay then check this for broken wires. My 106 diesel had a problem that I tracked back to a broken wire RIGHT at the base of the plug.
From memory, the glowstart relay on these is very similar, so perhaps that's worth a try?
Phil
Check condition of all wiring from glowplugs to relay, sounds like a broken or loose connection to me.
As Andre said a step by step guide of your problem and how intermittent it is will help us diagnose..
How many miles has your van done??
Yesterday 02:32 PM
Berlingo 2026
Last Post: xtimex
Yesterday 05:06 AM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
Weird Air in Fuel Problem
Last Post: tomhick024
27-06-2026 03:25 PM
