  • 31 Vote(s) - 3.13 Average
Changing door mirror
I need to change the door mirror on my Berlingo, as it was broken off by someone last night :censored:.
I've looked on e-bay and there don't seem to be any with the coloured panel on - is this something that is fitted afterwards?
Are they easy to change?
I think the coloured panel is clipped on to a standard black mirror.
To remove the mirror I believe you have to remove the door card to disconnect the wiring. The mirror trim on the inside just pulls off and the mirror is held on with 3 Torx screws.
It's not the wired one - as the wired one is on the passenger side and the one that was broken was on the drivers side, and is just a manual adjustment one.
There is still some wiring for the mirror heating. I know you can disconnect the glass from the mirror but I still think you need to disconnect the mirror from the car from behind the door card.
Im pretty sure the coloured part is clipped on afterward.
I broke mine and re-used the colour coded bit as that was still intact.
Is the colour bit damaged on your original one, assuming you still have it?
No - the coloured part is fine, it's most of the rest of it that isn't
Then it can be re-used, by carefully taking it off and refitting to the new one.
I actually bought the van one for my multispace with no heated bit to it because it was far cheaper and just did without the heated part by not connecting it.
I think I glued the colour coded bit to the new one as the van one has a recess and the end result is exactly the same bar the heated bit.
[-] The following 1 user says Thank You to tucker for this post:
  • snaprails
Thanks - I have today bought a new mirror from the 'bay and will hopefully have it fitted at the weekend, time and postal service permitting!
Either that or I will end up keeping the makers of gaffer tape in business.
I've taken the old one off as the gaffer tape decided to fail - just need to go to the local parcelforce depot tomorrow and collect the new one.
Spot the Berlingo(s)
Today 12:20 AM
knocking from rear
Yesterday 04:59 PM
Last Post: Andhall
Yesterday 04:59 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 01:45 PM
» Replies: 18
An alternative to Diagbox - Topdon Artidiag 800B...
Last Post: swawp
Yesterday 09:41 AM
» Replies: 26
Berlingo 07 won't engage 2nd gear
Last Post: Kyleonsite
14-01-2025 08:28 PM
wipers
14-01-2025 06:17 PM
Last Post: xavier988
14-01-2025 10:23 AM
footwell fan
Last Post: de62
13-01-2025 10:13 PM
rear washer fires front?
Last Post: Brooky325
13-01-2025 10:00 PM
