  • 7 Vote(s) - 3.86 Average
[Engine] Oxygen Sensor Wiring
Hi
02 Multispace Forte MFNFU
P0135/P0141 fult codes and using a lot of fuel.
Sonsors and fuse replaced but errors return.
Upon investigation "mouse nest" found under the air filter.
No obvious wiring damage but suspicious.
Does anyone have a wiring diagram that covers this and some tips for tracing/resolving?
Cheers
Does it have the Sagem ECU?
If so, there's schematics in Haynes 'Professional Techbook' 3558:
Engine Management and fuel injection systems
(EMS DATA Vol 1 - Alfa Romeo to Mazda )
There's 4 wires running to the sensor.
According to the book(and Sagem/Lucas SL96 ECU)
1 - To GND
2 - To Fuse F11, 15A rating.
3 - Pin 22 on ECU connector.
4 - Pin 4 on ECU connector.
On Magneti-Marelli MM 8P MPi DIS
1 - to GND
2 - to Fuse 3
3 - Pin 29 on ECU connector
4 - Pin 12 on ECU connector.
Additionally, 3 and 4 seems to be a shielded cable, and the shield is connected to 16 on ECU connector.
Bosch Motronic MP 5.2
1 - to GND
2 - to Fuse 11, 10A rating.
3 - Pin 28 on ECU connector
4 - Pin 10 on ECU connector.
Additionally, 3 and 4 seems to be a shielded cable, and the shield is connected to 14 on ECU connector and GND.
Side Light Bulb Holder
Yesterday 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
