  • 6 Vote(s) - 2 Average
thermistor or is it a choke flap ? how to check it ?
on my 02 berlingo diesel 1.9 early type engine ,is what looks like a big choke flap/thermister and small valves beside it on the intake side ,its fitted onto the the front of the intake manifold . looking at mine with the airfilter pipework removed ,this choke flap is always in the open position. anybody on here know how to test or fix this gubbins and my engine seems to run fine but id like some info if anybody has it thanks fellas Smile!
(17-06-2013, 05:38 AM)corij Wrote:  on my 02 berlingo diesel 1.9 early type engine ,is what looks like a big choke flap/thermister and small valves beside it on the intake side ,its fitted onto the the front of the intake manifold . looking at mine with the airfilter pipework removed ,this choke flap is always in the open position. anybody on here know how to test or fix this gubbins and my engine seems to run fine but id like some info if anybody has it thanks fellas Smile!
Hi, this is the EGR (exhaust gas recirculation) control valve. In theory when the engine is not under load,cold? the flap will close and allow exhaust gas to be recirculated into the inlet.
The flap is vacuum operated from a control solenoid and vacuum reservoir located near the battery.. it should normally be in the open position allowing "fresh" air into your engine...
As many do I believe the system is tosh and have disconnected mine on my van and blanked off the exhaust outlet.. Feel free to see how much black gunk is in your plastic manifold, all caused by this invention designed to reduce emissions!! Smile
cheers for the info, so how did you blank off the exhaust outlet?
http://www.berlingoforum.co.uk/showthread.php?tid=3348
this thread covers it really!
enjoy..Smile
Corij the thread linked by adam is a good one but you need to keep your wits about you as a lot of the replies relate to the chaps with the 2.0 engine. Basically you can do it with success by plugging the vac lines as suggested by Ron as then the exhaust fumes never enter the engine as the egr doesn't get the signal to open.
I've done my 1.9 and am pleased with it, I also did the same to my C15.
If you try and blank at the exhaust pipe the access is difficult and you may strip threads giving you major work.
Look here for how I blanked off my pipe.... 3rd page you'll see a photograph
http://www.berlingoforum.co.uk/showthrea...hlight=egr
Mileage
Yesterday 04:33 PM
eolys
Last Post: magoo1
19-05-2026 03:02 PM
Rattling calipers
18-05-2026 05:36 PM
Yet another ABS fault
13-05-2026 05:57 PM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
