  • 7 Vote(s) - 3 Average
Permanent live inside
Hey all,
Can you please tell me where the easiest place is to splice into a permanent live inside the car please.
Its for a 12 volt fan.
Needs to be nice and easy to get to please.
What's the amperage rating on the fan?
Sorry I haven't a clue, Chucked the box out. It doesn't say on the fan either.
Its says on a review its between 10-15 watts and might only need a 1.5-2 amp fuse.
Its this one
http://www.amazon.co.uk/12v-Delux-Oscill...ds=car+fan
If you plan to mount it on the dash, or near the centre console, it might be an idea to check out the wires going to the stereo, as some systems at least has one wire to the ignition switch and the other to permanent 12V.
Another option is to track the wires going to the switch for the heated seats, if you have that(may not be standard in all models in all countries) as that is also listed as getting power from permanent 12V acording to my manual. (An added bonus is that you're unlikely to use both at the same time... )
Easiest place would be at the rear of the 12 volt charging socket, wouldnt recommend messing with the stereo wiring tbh.
(20-06-2013, 06:33 AM)Lighty Wrote:  Easiest place would be at the rear of the 12 volt charging socket, wouldnt recommend messing with the stereo wiring tbh.
But isn't the 12 charging socket switched on and off with the ignition?? I suppose if i got the eco mode turned off that would cure the problem straight away.
I am guessing it needs to be a citroen peugeot dealer and not any old garage??
Permanent live would be straight from the battery, do you want an ignition live or do you want the fan to run with the key removed ?
Yes it needs to be run with the key out hence my question about one inside rather than running a wire from the battery.
New Berlingo Anyone????
Last Post: msw109
Today 08:25 PM
FK Lowering kit actual drop
Last Post: Matt Haigh
Today 05:05 PM
My new partner (well it’s the same van!)
Last Post: dumdum
Today 04:05 PM
Lowering fun
Last Post: northroadycles
Today 11:12 AM
Plug phone into stereo?
Last Post: LukeLog
Today 10:27 AM
Modutop Door Hinges - Cable tie repair
Last Post: ghost123uk
Today 09:14 AM
Last Post: ffrenchie
Today 09:00 AM
» Replies: 627
How Often Does AC Need Re-Gassing?
Last Post: cancunia
Today 08:51 AM
» Replies: 18
Loose connectors under dash
Today 07:18 AM
How did the Berlingo get it's name ?
Last Post: hawaiianblue
Yesterday 05:30 PM
