Threads: 5
Thanks Received: 4 in 4 posts
Thanks Given: 3
20-06-2013, 05:43 PM
(This post was last modified: 20-06-2013, 05:52 PM by daz1.)
Can anyone help. I think my auto adjuster on my clutch cable has go and I need to work out which gear box I have to get a replacemen. Also not shore which engine I have the dw8 or bw8b is there an easy way to tell which engine and box you have.
Ment to say it a 1.9 mulitspace 2001 on a 51 plate.
Threads: 67
Thanks Given: 1,045
Look at the nearside end of the gearbox. How many bolts hold on the tin cover?
• daz1
Threads: 5
Thanks Given: 3
Thanks for the help. I have found out that it's not the cable but is the clutch, just booked it in to have it done did not think £230 was bad for clutch an fitting.
