  • 4 Vote(s) - 3.25 Average
Mk2 - Mk1 Axle
Hey Guys I have a mk1 berlingo with a bearing gone in the rear axle. I can get my hands on a pretty fresh Mk2 axle for cheap off a mate but do any of you know if they are a straight swap ??
Cheers Kenny Confusedalut:
If you mean M59 rear beam assembly into an M49 bodyshell, no problems with the bolts - not 100% on the brake hoses/tubing being identical.
Gentleman thanks very much for the reply. Mines a 2001 pre facelift and the other axle is out of a 2006 facelift mk2. So I'm assuming mine is the M49 and the 06 Lingo a M59.
Cheers K
That's right.
I can confirm that what addo said is correct fits perfect.
[-] The following 1 user says Thank You to KennyNire for this post:
  • addo
how easy was it to remove your old 1?
MK1 Berlingo, Y-Reg 1.4 Petrol Now LPG Converted.
It wasn't to bad. You need a long T50 torx bit to remove the bushings. If you don't you can remove the two 13mm bolts that hold the bushings to the axle and leave the bushings in place. Just make sure you have a 4lb hammer and plenty of WD40.
Newbie
Last Post: Vmkst
Yesterday 08:48 PM
MyBerlingo App Service History
Last Post: Requiem
13-02-2026 10:43 AM
Mk 3 K9 blower not working
12-02-2026 04:57 PM
Diagbox 9.91 free download
Last Post: Slowmo
11-02-2026 06:29 PM
Last Post: Slowmo
11-02-2026 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
