  • 4 Vote(s) - 1.5 Average
coilovers
Hi guys I finally got round to installing coilovers.ta tecknix ones were recommended by a user of this forum, but there is a problem when driving ay slow speeds (up to about 40) they are very clunky, it sounds like my front end is abot to fall of to be honest I've checked everything is tight and I just cant seem to find what is making thisuunbearable noise I was wondering if anyone could share some light on the matter as I know there are people on this forum with the same set up as me thanks
They do look great by the way
Attached Files Thumbnail(s)
The ride they give is harsh, Though to be honest the knocking could be anything..Topmounts/bottom arms ect. Have you tried jacking it up and checking the wheel for play? I know when mine was recently knocking it turned out to be the bottom arm and droplinks.
'04 Peugeot Partner HDi LX. Lows, Leaks and Wellers. Now matt grey and dent free Smile
[-] The following 1 user says Thank You to PeteA for this post:
  • owenT
Thanks pete I discovered the problem it was the helper springs clunking so I just rapped them in duct tape for now but they will be coming off when I do the torsion bars thanks for the help
In My van, occured something like that. It was the top oh the shock knoling on the ecu coverage! Wink
I never use the helper springs, as on bumpy roads they do exactly as you describe, and given the design on the coilover, the main springs will never re-seat incorrectly anyway. I also cut down the bumpstops as if you're going quite low, you'll find shock travel is restricted by them.
[-] The following 1 user says Thank You to FeuxLingo for this post:
  • owenT
Diagbox 7.57 download
Yesterday 09:13 PM
Yesterday 05:26 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
