  • 6 Vote(s) - 2.33 Average
NEWBE TO AIR CON BERLINGO
Hi all I have just bought a 1999 berlingo multispace wheelchair converted by brotherwood.
the elderly gent I purchased it from told me he had never used the air con.
when I got home I found I could not get the heater blower to work, checked all the fuses to do with heater ac etc all seem fine.:brickwall:
car has done only 2000 miles in the last 4 years now has 70000 on clock.
service history says last service at 61000 but no other info
I tried the blower with the air con button on, and also in the off position.
Any ideas pleaseConfusedcratch:
Well for a start, the A/C will not work without the blower coming on. You will need to address this as a separate issue 1st, but if the previous owner never used it. It is unlikely to work without at least a regas.
Get your blower sorted , then worry about the A/C
(25-06-2013, 07:10 PM)Lighty Wrote:  Well for a start, the A/C will not work without the blower coming on. You will need to address this as a separate issue 1st, but if the previous owner never used it. It is unlikely to work without at least a regas.
Many thanks Lighty will try to find auto elec.
Hi is the blower motor easy to get at , any advice would be much appreciated
Blower is in the passengers footwell.
Under the glovebox, pull down the carpet and you will see it there
many thanks Coco
Today 12:02 PM
Berlingo 2026
Today 03:17 AM
Yesterday 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
