Threads: 12
Thanks Received: 7 in 6 posts
Thanks Given: 5
26-06-2013, 10:44 AM
(This post was last modified: 26-06-2013, 11:03 AM by dwr400.)
I'm very unfond of the feature that lights turn on when car is started, so is there a clue as to how to make them be off, when the switch is off.
Is it just a matter of taking certain fuse, relay out?
Threads: 67
Thanks Given: 1,045
That's what most people here would call the "DRLs".
Fairly sure you can turn them off with Lexia.
Threads: 12
Thanks Given: 5
Can daylight running dipped beam be equaled with low wattage halogens or daylight LED's, the actual DRLs?
I think DRLs have separate switch, but in my case, when I have light position in "0", lights are turned on. Also, they stay turned on when I turn them on, with the difference that dash gets lit.
I'd just like to make the "zero position" on the switch actually do nothing.
Lexia again?
Threads: 67
Thanks Given: 1,045
I think so. Possibly you could ask Lighty.
Threads: 52
Thanks Given: 87
5
On my mk 3 I enabled that feature with my Lexia so it can be disabled as well.
