26-06-2013, 04:46 PM
(This post was last modified: 26-06-2013, 09:33 PM by howie50.)
Hi all! My 2001 berlingo has a idle speed problem. It either runs too fast or too slow and sometime cuts out. Also when lifting off the gas it sounds and feels as though you are using the engine as a brake with no revs! Any ideas welcome!
Threads: 20
Thanks Given: 2,126
18
You don't say whether it's petrol or diesel.
Either way check the fuel & air filters first.
Strawberry flavoured windows
Threads: 29
Thanks Given: 67
20
Is it showing any fault codes ? Last time I had that problem on a car it was the air flow meter and throttle position sensor, it could be both or either if it's petrol.
