  • 13 Vote(s) - 3.46 Average
Red light on dash
Hi all,
have a 2001 1.9D berlingo. A red light has started appearing on the dash albeit intermittantly. It looks like a saucepan lid with a wavy line under it. Thought it could be the brake fluid level, but that is ok. Haven't got the hand book and can't find either a handbook download or any reference to this online.
What is it?
Cheers,
Trevor
Coolant level indicator?
Indeed it is. Finally got through to a mechanic at citroen.....after lots of persuading that I was not going to "bring it in" just to find out something that is is the handbook!.......not easy to get past reception!
Level ok though, probably the sensor.
I too have the 2002 1.9 diesel multispace. That light comes up on mine. Is it the coolant temp sensor?
Indeed it is, probably a dodgy sensor or low coolant
[-] The following 1 user says Thank You to brodfather11 for this post:
  • Pat Fay
Thanks for that brodfather11. Much appreciated
Yesterday 12:17 PM
indicator problem with trailer
Last Post: wbchevron
Yesterday 09:32 AM
DV6BTED Crank Pulley bolt torque spec
14-07-2026 01:49 PM
DV6B was running then cut out, Will crank but no...
Last Post: jj9
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
Last Post: IHateMyDadsM59Berlingo
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
