29-06-2013, 08:03 PM
(This post was last modified: 29-06-2013, 08:05 PM by BigDunkyWunky.)
Aawwww I'm back again.
Coolant warning lamp came on in the warning light strip. Turned the heater flat out hot to warn me if it ran out of coolant on the way home. Luckily it started blowing cold air just as I pulled into my street, so I parked up and left it to cool down.
Put a couple of litres of water in and noticed a pin stream of water jetting out from just above the oil filter. Where the bottom radiator hose connects to that casting that mounts the oil filter, there appears to be a pin hole in the casting about half an inch down from where the hose connects to the casting.
I imagine I'll need that casting, a gasket and a new oil filter? If so, anyone got the casting for sale? Or are these dear to buy new?
Any tips on replacement of this bit from anyone who has had to do the same job?
2000MY 1.9D Berlingo Van
Cheers
D
Cheers
D
