  • 16 Vote(s) - 3.19 Average
HELP GEAR BOX SOUNDS LIKE FAN BELT SQUEEL AND JUDERING BAD
HI my gear has started making a high pitch noise when the clutch is pressed, when you go to pull of the its juddering the whole van
any help would be needed before i but new box and problem could still be there ?????
The squealing is probably the release bearing on the clutch and it sounds as if your clutch could also be worn out.
  • berlingo 2004
it was fine coming from work parked up for 10 mins went out then it started its all come on straight away not a problem thats een getting worse over the weeks all in 5 mins and now to bad to drive. thanks for reply
ill give haynes a check for your symptoms, dont have it to hand currently.
[-] The following 1 user says Thank You to Andre for this post:
  • berlingo 2004
thank you appreciated.
Sounds exactly like my symptoms. If it is the same as my symptoms then it will be the release bearing. See here: http://www.berlingoforum.co.uk/showthread.php?tid=322
I suggest you do not drive the vehicle as when the release bearing lets go you'll be stuffed by the side of the road. With the vehicle in neutral, handbrake on and engine running look at the clutch release arm in the side of the gearbox and see if it is chattering, if it is I'll bet its the knackered release bearing jumping around on the gearbox input shaft. If you want to know anymore give me a shout
1.9d Mk2 (M59/BE4/5) with battle scars from a conservatory attack. Previously owned a 1.4i Mk2 Forte.Confusedalut:
[-] The following 1 user says Thank You to divingscubaboy for this post:
  • berlingo 2004
looks like a busy day for me tommorow lets hope its not a hard job thanks for reply may still need a box as 3rd gear sometimes crunches. is it a hard job too change release bearing
(10-05-2011, 09:39 PM)berlingo 2004 Wrote:  looks like a busy day for me tommorow lets hope its not a hard job thanks for reply may still need a box as 3rd gear sometimes crunches. is it a hard job too change release bearing
Id put a whole clutch kit in it - juddering whilst taking up drive can also be a characteristic of a knackered friction plate
Phil, you get the late night user award(!) Your our forum bat Tongue
Courtesy of Haynes.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
