Threads: 101
Thanks Received: 276 in 220 posts
Thanks Given: 384
Thinking of getting an OBD app for my smart (?) phone.
As many of you know I am more used to working/racing big V8s from the 60s & 70s, so am not familiar with the electronic witchcraft on modern engines.
So....
What do I need, what connects where, what cable do I purchase, how much will it cost, what can I break?
Answers on a postcard, or in the white box below. :thumbsup:
Threads: 67
Thanks Given: 1,045
It won't get very much useful info from your PSA cars at all. Probably more popular with the fishing types, as you will get the odd red herring thrown in.
Can't you build us a Blingo with full ladder chassis, wheelie bars and a stroked 460?
Threads: 52
Thanks Given: 87
5
I use an app called Torque Pro and like it. Aside from that you need to get an OBD II bluetooth adapter. The adapter plugs into the ECU socket under the steering wheel and then talks to your smart phone via bluetooth. Not an expensive item either. Works a treat.
The following 1 user says Thank You to 3rensho for this post:1 user says Thank You to 3rensho for this post
• j90xxx
Threads: 101
Thanks Given: 384
Guessing an Ebay search for the adapter?
Threads: 52
Thanks Given: 87
5
This is the one I use. There are a number of
others to choose from.
• j90xxx
Threads: 48
Thanks Received: 272 in 229 posts
Thanks Given: 4
20
I have one of those.
Doesn't work with older Berlingos.
