  • 2 Vote(s) - 2 Average
oil above cam belt
Hi all
i washed my berlingo yesterday and when i popped the bonnet to clean around the frame i noticed oil around a part just above the cam belt.
I dont know what this part is called or what could be causing it.
Any ideas!!!
Attached Files Thumbnail(s)
Sad
105 views and nobody knows what the part is called!!!! Sad
oh well i will find out from my local garage.
(10-07-2013, 03:57 PM)gamebuster Wrote:  105 views and nobody knows what the part is called!!!! Sad
ISNT THAT A PIC OF THE AUXILLERY BELT.
COULD IT BE COMING FROM AN OIL BREATHER?
Naa, this is oil seeping from the pipe going from the intercooler to the maf.. Just dtake this pipe out and clean it , -- and the pipe from the turbo to the intercooler too and the intercooler as well. Also clean the pipe from the air filter to the Turbo. I drilled a small hole at the lowest point of that, so taht oil coming from the breeder system can simply drip out.
what Hansw says its just an accumulation of oil in the intercooler pipe work - basically your turbo is passing some oil but this is not that unusual and nothing to be too concerned about.
But you can take it to a garage if you want?
only-- the maf sensor does not like oil,-- not that cheap if it goes, -- and its unlikely the turbo itself-- more likely the non existing catch can in the breeder system. But you find out once you take the pipes apart.
Thanks guys Smile
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
28-01-2026 06:13 AM
Last Post: Big_Jim1967
27-01-2026 08:32 PM
