Threads: 16
Thanks Received: 10 in 9 posts
Thanks Given: 2
Afternoon all!
The radio in my berlingo is playing up. When in RDS mode it seems to want to search every 5mins. (Whilst I whistle to myself until the radio appears again). Why would this be?
Something come loose/broke?
Thanks Received: 17 in 13 posts
Thanks Given: 10
Mine does that frequently, but I live in bad signal area. If yours has just started it check you Ariel is still there or has not come loose.
Threads: 32
Thanks Given: 13
Sounds like a poor signal or ariel as mentioned. However, can't just disable the RDS function for the time being so it doesn't keep trying to search for the best signal?
Threads: 50
Thanks Given: 743
Loose aerial plug at the rear of the radio....water in the aerial base (quite common).
Threads: 51
Thanks Given: 23
Surely it's just a matter of pressing the AF button? Once you have AF disabled it should be ok
Malc
Stupid computer!
