  • 2 Vote(s) - 3.5 Average
Headlights staying on
Hi Folks, I recently bought a lovely green (ex Irish post van) berlingo and something has been bothering me. When the lights are in their off position the dipped lights are on and the dash lights are off bar the light which shows your lights are on. When I turn the stalk to side lights, naturally the side lights come on and so too the dash lights and also the same then when I turn the stalk to the dipped lights. I guess my question is is there anyone out there with a 07 berlingo whose lights dipped lights are on when in the off position? Would this have anything to do with poor display from the radio read out on the top of the dash? Any help greatly appreciated.
the poor display is due to the little bulbs gone at the back of the display, -- they are standard dash bulbs and easy to replace.
Headlight issue, is down to the BSI, -- so ask Peugeot, if they can turn off the daylight option on your van.
The display is supposed to dim if the lights are on to reduce night time glare
Correct.
The radio display is 'dim' because your lights are on and the van thinks it's night. Confusedillyme:
actually this is not the case, -- the car thinks the lights are off, and turns off the lights of the clocks illumination. The display should be on full light, and if not, then the bulbs are the problem.
There seems to be the option to have the dims on regardless the position of the switch, as it is deemed to be a safety feature to be seen earlier.
This option can be switched on and off by Peugeot in the BSI module.
Hi all, thanks for all the replys!! I took off the display unit, took out the bulbs, brought them to the local autoparts shop and 3 euro later ive a lovely bright display so thank you for that one!! I went to my local garage who confirmed the thoughts of everyone, yes it can be swithced off but at a cost of about 90 euro!! Looks like they will be staying on :S
Have a search for someone in your area that has the lexia software that could sort it out for you. There are club members on this and and other french car forums that offer their services for a small fee or drinking tokens.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
