Threads: 11
Thanks Received: 4 in 1 posts
Thanks Given: 7
how do you remove the plastic bracket that holds on air box on with a nut and a bolt can bracket come off without taking more components off
Threads: 5
Thanks Received: 31 in 27 posts
Thanks Given: 2
The stud should unscrew and the bracket should slide up. You can get a metal replacement if yours is knackered.
The following 1 user says Thank You to JohnM for this post:1 user says Thank You to JohnM for this post
• bigbubba85
Threads: 16
Thanks Received: 3 in 3 posts
Thanks Given: 2
I have a meyal bracket for mine to but it`s not as simple as "sliding it up" as there are 2 fixing points, one of them is also part of the fixing for the EGR valve as far as I can see.
Thanks Given: 188
23
On mine there is a nut and the other is a bolt and the only way i could get the old plastic one off and the new metal one on was to remove some of the egr pipework. Why they just didnt use 2 bolts is beyound me. But it does give you chance to clean the carbon crap out of the corrigated pipe work.
Are we there yet?????
Threads: 11
Thanks Given: 7
tightened up the injectors smell gone now
