  • 3 Vote(s) - 2.67 Average
removing oil turbo pipe that gets cloged 1.6hdi
has anybody ever taken off the oil pipe that has the gauze filter init was going to clean mine out at the weekend while i have the van in the garage
You might find posts from Lighty or Polar on this matter. I know the former does it as a matter of course on all turbo replacements.
You may find most of the info you need on this thread
http://www.berlingoforum.co.uk/showthrea...123&page=2[/i]
Yes, did it the other day, -- about 1,1/2 plus work
Kat has to be removed to gain access to the buttom connection, where the filter is in. Turbo stays in place. Radiator stays in as well, but nerds to be covered so that it does not get damaged.
You can get away with disconnecting the cat from the turbo and the block, then lean it forward leaving the bottom joint attached to the flexible section. You have to take the front heat shield off as well.
Did mine today, mesh filter was as clean as a whistle, still removed it though. Would be better if the mesh was at the turbo end, that way you could clean it every week if you wanted. Perhaps that's the answer!
Last Post: JPCoetzee
Today 03:52 PM
OIL Drip
Today 01:49 PM
Today 01:42 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
Potential Purchase!
09-03-2026 03:03 PM
