  • 5 Vote(s) - 3 Average
speedo drive unit
Hi i removed the gearbox to replace the clutch noticed the speedo drive unit is loose inside the gearbox is this normal,also noticed 10 small ballbearings lying on the floor ,can anybody help,thanks im a newmember:
Ouch!
No, the drive is NOT supposed to be loose.
Lets hope there wasn't 11 or 12 of those balls in the bearing...
(I have no idea how many there are supposed to be. If one is loose inside, the entire gearbox is in danger of being ruined if you try to use it)
EDIT:
The Gearbox is a very delicate piece of Hardware. It's NOT something that every Tom, d**k and Harry can open up and repair. You may need to pass this task onto a specialized garage/workshop.
I have some experience(dumped the innards from a Renault 18 Gearbox with broken mounts into the shell of one that had been run without oil. My brother is a clutz... ) and no... I wouldn't touch a modern gearbox designed for a transverse mount, like the one in the Berlingo.
Which gearbox is it?
The MA is famous for dropping its balls.
20-07-2026 02:51 PM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
