Threads: 9
Hi
For the Donegal roads the front suspension is too low even though it is in perfect condition.
Is there a easy way to bring it higher?
Maybe different springs, or struts?
Which 15" rims fit?
Threads: 50
Thanks Given: 743
If you have 14" rims at the moment, changing them to 15" rims will make no appreciable
difference as the 15" tyre sidewalls are not as high as the 14" ones and the overall diameter
of both wheels is almost identical. If you raise the front you'll also have to raise the back, but it
looks as if that's what you're going to have to do...
Threads: 83
Thanks Received: 397 in 340 posts
Thanks Given: 179
21
Surely its a job for the county council to fix the roads
