  • 4 Vote(s) - 2.25 Average
Temp gauge in summer
This is the first proper summer we've had since I bought my Berlingo 1.9D!
On the motorway it will run along flat out and barely move the temp gauge, but in town it gets quite hot quite quickly! Although never into the red.
It's had 2 coolant changes and a new thermostat last year, and is free of air locks as far as I can tell.
Is this normal? Thanks all
Mine (same engine) usually sits at 80 degrees (indicated). If I get stuck in a jam then it can move up to 90 or just about 100 before dropping indicating the fan is kicking in. Takes about 5 minutes to start rising above 90 though. In this weather I've noticed that the gauge seems to sit 2 - 5 degrees higher and moves much more. Doesn't seem worringly high though.
Malc
Stupid computer!
[-] The following 1 user says Thank You to crickleymal for this post:
  • chronyx
They all do that Sir! Big Grin
[-] The following 1 user says Thank You to chronyx for this post:
  • addo
I rarely do town work but can say that once the thermostat has opened my 1.9D sits at an indicated 82 degrees whether it is summer or winter. I did notice the other day the gauge went up to 92 after a good motorway run followed by queuing on the slip road to exit.
Normal behaviour indeed. Just ensure the radiator fan kicks in when hot you should be able to hear it.
Just spent a hour in traffic at Hook on the A3 and can now confirm the fan works!
Thanks all
Today 08:36 AM
» Replies: 15
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
