wiring diagram 2004 multispace 2.0 Hdi
Threads: 9
Thanks Received: 6 in 5 posts
Thanks Given: 9
Hi,trying to find a decent wiring diagram for my 2004 multispace 2.0 Hdi ,looking for a diagram for the front fogs and also the horn.
Thanks in advance,Bob.
Threads: 9
Thanks Given: 9
(19-07-2013, 06:00 PM)bobflem Wrote: Hi,trying to find a decent wiring diagram for my 2004 multispace 2.0 Hdi ,looking for a diagram for the front fogs and also the horn.
Could some one point me in the right direction please.Haynes diagram is pretty useless,there must be diagrams for my model and year.
Any help would be much appreciated.
Thanks,Bob
Threads: 9
Thanks Given: 9
(20-07-2013, 06:21 PM)bobflem Wrote: (19-07-2013, 06:00 PM)bobflem Wrote: Hi,trying to find a decent wiring diagram for my 2004 multispace 2.0 Hdi ,looking for a diagram for the front fogs and also the horn.
Thanks,Bob
I have 4 wires that need connecting under the passenger front wing, i assume 2 would be for the horn 2 for the front fogs.I have checked to see if any are live when horn is pressed or fog lights switched on but there is no power.I have also checked all fuses they seem ok.Is there anyone on the forum that would know where i can get a diagram for my model an year,there must be other people who have had problems with wiring.The haynes manual has no diagram for front fogs.
Any help please.
Threads: 42
Thanks Received: 409 in 366 posts
Thanks Given: 137
31
22-07-2013, 02:14 PM
(This post was last modified: 22-07-2013, 06:26 PM by brodfather11.)
Rustscrat is your man for these diagrams. May be on hols at the moment .
There has been a lot of horn problems, :whistle:
There is a earth point near the n/side wing for the horn should be checked.
I think they both fused from the engine fuse box? . There has been problems with that fuse box connections/corrosion underneath . try that for good contacts.
Threads: 9
Thanks Given: 9
(22-07-2013, 02:14 PM)brodfather11 Wrote: Rustscrat is your man for these diagrams. May be on hols at the moment .
Thanks for reply brodfather11 just taken com 2000 to bits found the long ribbon had broken,looks like i will have to source out another one.Will still have to find a wiring diagram for fogs and horn as the wires have been cut.Checked earths and fuses cleaned up connections,once i get another com 2000 i will hopefully get some results.
Cheers,Bob.
Threads: 18
Thanks Received: 468 in 294 posts
Thanks Given: 211
Here you are.  alut:
2006 2.0hdi 600 with bench seat.
Threads: 9
Thanks Given: 9
The following 1 user says Thank You to bobflem for this post:1 user says Thank You to bobflem for this post
• Rustscrat
Threads: 0
Hi, I am looking for the fusebox layout for a 2006 1.6D .
My rear lights have stopped working but the front lights are working fine. I know that its not a fuse problem but if I know what fuses are sidelights I will be able to bypass the BSI if needs be. Thanks
Threads: 2
Thanks Received: 6 in 3 posts
Thanks Given: 7
@ owler,, sounds like a bad earth for your back lights,, check it out
Threads: 0
(08-04-2014, 01:57 PM)joemc20 Wrote: @owler,, sounds like a bad earth for your back lights,, check it out
All other lights are fine i.e. brake lights, reverse lights. indicators so its defo not an earth fault.
Thanks for reply though
Diagbox 9.91 free download
Last Post: Slowmo
Yesterday 06:29 PM
Last Post: Slowmo
Yesterday 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
Last Post: chrisl
29-01-2026 07:06 PM
28-01-2026 09:18 PM
Cheap(er) oil
28-01-2026 03:39 PM
