Threads: 2
Hi,can anyone tell me why my rear doors won't lock. The key turns to the open position fine but not the closed. I don't want to force the key incase it snaps. Any ideas?
Threads: 52
Thanks Received: 82 in 67 posts
Thanks Given: 9
Do you mean van rear doors, multispace sliding doors or boot?
Threads: 2
Yes sorry I mean the rear doors. I don't have side doors. It use to work fine then slowly got stiffer to lock now you can't turn the key. The drivers door was the same but this seems to have cured itself.
Threads: 147
Thanks Given: 263
11
Maybe of squirt of WD40 wouldnt do any harm, it is an older van.
Threads: 32
Thanks Given: 13
A fundamental rule of life - lubricate before penatration..........
Threads: 52
Thanks Given: 87
5
12-05-2011, 12:09 PM
(This post was last modified: 12-05-2011, 01:17 PM by 3rensho.)
Powdered graphite often woks in sticky locks as well. If it's corrosion then WD-40 will work wonders.
Tom
Quote:A fundamental rule of life - lubricate before penatration..
Oh, you be bad
So true!
Threads: 2
All lubed up but still no joy. I managed to get it to lock out of about 100 attempts. What next?
Threads: 52
Thanks Given: 87
5
Does the key turn freely in the lock and it still doesn't lock or does the key not turn inspite of the lube job?
Tom
Threads: 2
The key won't turn anti clockwise in the barrel. Clockwise is fine.
Threads: 52
Thanks Given: 87
5
Ah so, well sounds like it's time for a lock smith. That's all I can think of at this point.
