Thanks Received: 3 in 1 posts
I have just been looking over the car before making a long journey and have found...
The oil level too high, it is on the twist bit on the dipstick so about 2 cm over the max indent.
I had the oil changed a month ago, and the garage forgot to change the filter that badly needed changing, so got them to do it later when I had some other work done. I was expecting the oil to be low and it was very so, I got my wife to fill it up, as I wasn’t there, and promptly forgot about it. Until now, so my question is do I need to completely drain it and re-fill?
Or is it ok to leave it is ?
Thanks in advance
Threads: 80
Thanks Received: 392 in 335 posts
Thanks Given: 164
18
I would drain off a litre and then carefully top up with new to the correct level.
You dont want oil being forced into places it shouldnt go
Yes good suggestion, I think it would give me more piece of mind too.
This might sound daft
But, to drain just a litre- will it mess with the sump nut and washer,
As obviously if I was going to drain it all I’d replace them?
As Its gonna be messy..
Threads: 48
Thanks Received: 272 in 229 posts
Thanks Given: 4
20
29-07-2013, 05:18 AM
(This post was last modified: 29-07-2013, 05:18 AM by Gadgetman.)
Yeah.
I bet they even used one of those daft pumps to suck the old oil up through the dipstick tube, leaving the worst crud still in the sump...
(If they didn't, one of those pumps would be OK for removing the excess. But as you also need to swap the filter... )
Threads: 67
Thanks Given: 238
50
29-07-2013, 07:30 AM
(This post was last modified: 29-07-2013, 07:31 AM by geoff.)
Drop the oil yourself and replace it along with the filter.
For absolute piece of mind pour back in a measured amount of new oil and you can then check the accuracy of your dipstick level markers, probably a bit of an old fashioned practice but it has it place.
Talk about old fashioned ways anyone remember the common practice of parking the vehicle over a drain in the road and dropping the oil into the drain ? Not that I've done it of course ! Mind you the environmental chaps would soon be on your case if you did it nowadays.
Serieal Berlingo owner
Threads: 80
Thanks Given: 164
18
Sacrilege anyway -I use old oil/paraffin mix as chain oil in the chainsaws and as wood preservative for the sheds.
And in the flamethrower when the EA are snooping around.
The following 2 users say Thank You to evdama for this post:2 users say Thank You to evdama for this post
• RolyG, ron
