Threads: 25
04-08-2013, 10:28 AM
hi all,
just joined this forum.
have a citroen berlingo 1.6hdi 2008
can anyone advise on the gearbox fill and drain locations please
thankyou.
Threads: 12
Thanks Given: 16
37
The drain is pretty obvious on the lowest part of the diff housing underneath, we always fill them through the plastic vent plug on top of the box. just add the correct amount after draining. I dont believe there is a level plug.
The following 1 user says Thank You to Lighty for this post:1 user says Thank You to Lighty for this post
• RolyG
Threads: 32
Thanks Given: 18
The level plug is the fill plug, keep pouring oil in till it overflows.
Threads: 20
Thanks Given: 2,126
18
04-08-2013, 10:10 PM
(This post was last modified: 04-08-2013, 10:12 PM by ron.)
You can drain & them fill through the vent using 2ltrs.The level plug is on the metal cover seen from wheel arch.
Strawberry flavoured windows
