  • 5 Vote(s) - 2.2 Average
How to replace side lights on mk1 2001 w reg lingo 600 x
Got a mk1 2001 w reg lingo 600 x
Read the few forums i found but still can not work out how to replace nearside side light bulb. Ive twisted fiddled and pulled, no joy.
I dont even know for sure if whole unit goes forward or just bulbs back.
Cant get to the back to see!!!
please help
The sidelight is in the indictor lamp.
On the mk1 there's a hole in the n/s inner wing through which you can see the indicator bulb holder, put your finger in and press forward on the bulb holder as you press down with your screwdriver. The lamp should then pop out, needs a lot of force on the plastic lug though just where the colour of the plastic changes from greyish to black, not at the very end off the lug. Just tried mine, two seconds and it was out.
To change the bulb remove the bulb holder. To do that press the wire thingy in and pull it away from the bulb holder , you will be left with the bulb holder and with a small pair of pliers/strong fingers twist it anti clockwise.
If they haven't be disturbed for awhile they will be tight with the rubbery bits sticking together.
Bettery Issues - A Solution.
Today 10:45 AM
ignition lock ggrrrrrrrrr
Last Post: Jackalus
Today 10:01 AM
Engine Fan Running
Today 08:34 AM
Sound proofing windscreen
Yesterday 02:43 PM
14-11-2025 07:34 AM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
