  • 7 Vote(s) - 3.29 Average
Central locking button missing
Our Lingo Mk2 came with remote central locking, but, having fixed the rear lock, and judging by the missing button on the dash (it just has a fake blanking button) I'm assuming it was retro fitted when the alarm was installed by the previous owner. (I can't ask as it came to me via a dealer)
Does anyone know if I can add the dash lock b0tton so we can lock/unlock the doors internally? I'm not sure if the van is pre-wired for the motors or if new cables have been run into the doors as I've only looked at the tailgate so far. If the original wirng was used can I assume it's been tied into the ecu to control it?
Mine is retrofitted. I just press the button on the remote when I'm in the van.
I would do that but it'll arm the alarm, which will then go off if I open the door.
Pull out the blank, to see if the plug is behind. You could also strip the trim off one door and see if the latch is original or modified.
(06-08-2013, 07:17 AM)myo Wrote:  I would do that but it'll arm the alarm, which will then go off if I open the door.
Mine arms it only when the engine isn't running.
Have you tried it with the engine running and the doors closed?
Rear door filling with water
Today 06:56 PM
MOT Emissions repeated fail
Today 06:53 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
