  • 3 Vote(s) - 3.33 Average
Splitting the AC Box
I've eyeballed the diagrams and it looks very similar to a Xantia.
What I want to do, is remove the heater section of the heater box for cleaning/decrudding, and also split the evaporator box in-situ (to avoid degassing the airconditioning).
Has anyone tried such an adventure? :o
OK, splitting the heater box isn't too hard. Once the heater half is loose from the centre tunnel and firewall, there's only the two 10mm head bolts to wind out and a small goldy-coloured Phillips head screw. Flick the wiring AC harness out your way and all is well.
A fiver for anyone who can spot my 13mm combi Teng spanner in the photo - I can't find it. Sad
Splitting the AC section top-bottom is an unknown as of now. It's going to be tight!
What really annoyed me was observing the carpet is under everything. I have to clean the carpet as it's saturated with coolant and grime, so everything has to come out for the job...
[Image: eori.jpg]
Yesterday 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
06-06-2026 12:29 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
