  • 3 Vote(s) - 1.67 Average
Glow Plugs
Alright guys, just need some help finding the glow plug relay on my 07 1.6 hdi. Reason being i put fault code reader on the van and it's comming up with a fault with the glow plugs and need to sort this out before winter. Many Thanks
Got that on mine - duff heaters (all 4) try this thread -
http://www.berlingoforum.co.uk/showthread.php?tid=4345
Bought 4 new ones but as it started on the button all last winter, have not fitted them yet. :S
Have you looked to see what has to come off just to get at them and the horror stories of them breaking in the head! :eek::eek:
[-] The following 1 user says Thank You to BlingoBlue for this post:
  • V6BOY
Cheers for that, gonna change them this week Ive had bad experience with changing glow plugs before on my friends 2001 1.9 megane. One snapped in the head touch wood the Berlingo will hold up to the change!
Changed mine on my 2002 2.0 hdi a couple of years ago with no drama.
Never buy glow plugs from anywhere except motor factors, they have direct purchase lines from the factories, Ebay / Amazon and the likes have hordes of sellers selling counterfeit glow plugs and spark plugs for sale from China, the glow plugs heater elements snap off and drop onto the running pistons, fakes tend to have coarsely finished threads, that lock into the head threads once fitted
and they snap off in the cyl head when you try and remove them. Bosch, Champion and NGK are the main targets and arrive complete with security hologram.
The problem is the same with spark plugs, the electrodes come off and wreck engines, motorcycle engines are especially prone to damage from fake plugs. Cheap online bearings, filters and brake parts are all best avoided, I have purchased some real horror stories from cheap online sellers, some wheel bearings Ive seen will kill you. When I do purchase online, I use reputable companies only
Smear the new plugs threads with a fine layer of copperslip, I also use a cotton bud to ensure the head threads get coated too ( just a smear) and torque to the recommended setting, wrenches are available under £10 from motor shops, Whether you have an alloy or steel head, as with exhaust manifold nuts....its best to remove them from a hot engine.
^^good advice^^
I changed my glow plugs recently with NGK items. Makes a whole load of differance starting from cold. I never thought about a smear of copper grease thats a good idea but my engine was touch warm before I removed ny old ones. Came out with no probs.
I've always use copper grease too and never had problems removing them ..
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
