  • 32 Vote(s) - 2.13 Average
1.6 hdi misfire when cold
My 57 plate 1.6hdi 75 runs rough when cold but always starts first time, also noticed a little white smoke whilst running rough. After a couple of minutes it seems to run perfectly. Not checked for any fault codes as i dont have a code reader but looking to buy one if anybody has any recommendation.
Hi mate, try looking through these to see if it gets you any further before someone else comes along with some better info.
On the code readers, do a search as its been discussed here in detail before. If you still have unanswered questions, there are members who have been doing their own research whom iim sure would be happy to help you out.
[-] The following 2 users say Thank You to Andre for this post:
  • andyd76, j90xxx
It could be blocked/faulty injectors? My first port of call would be a leak off test to see if that turns anything up.
[-] The following 1 user says Thank You to steve valentine for this post:
  • andyd76
Hi Steve,
As you know, I have same year and engine.
Mine starts no problem from cold but "hunts" for about 15-20 seconds.
(Used to get "hunting" on old carbs on petrol engines; revs go up and down especially when cold.)
When first started revs go +/- 50 or 100 each side of tickover.
Been wondering what causes it, but doesn't last long enough to worry about. Runs fine after that, not miss a beat.
You got me thinking.... should I be worried?
Anyone any thoughts?
Martin
Sounds like what mine does,do you get a little white smoke for the first few seconds?
mines no smoke
is there a heaterplug set up on the HDI motors? If so, it sounds like there's a plug down getting inadequate heat into the combustion chamber causing improper combustion which the computer senses and tries to dial out by messing with the RPM
Can't say if there is any smoke.
Usually sitting up front at the time.:lol:
Sorry...:whistle:
Nothing seen in mirrors, so if there is must be very little.
Its only a very small amount of smoke for a few seconds, and yeah i've had the plugs out all about 1 ohm and appear to glow the same at the tip. I will investigate further but dont have much time at the moment so it may be a while.
Thanks for the suggestions so far, will report back any findings.
Yesterday 06:15 PM
removing front strut
Yesterday 06:10 PM
Strut Top Mounts
Yesterday 05:47 PM
Rear seat belt breakage
Last Post: Mad one
12-09-2026 06:09 PM
12-09-2026 05:49 AM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
