instal reversing sensor on berlingo mk3
hi. the citroen dealer has installed backup sensors on my car.
drill hole's in bumber. place the sensors.
drill hole behind the cover on left hand side.
get the cabels inn the car and use silicone to plugg the hole.
now take the buzzer and mount with glue or velcrow in the viod upper left side.
run the cable down to the tail light.
connect the sensor's and the buzzer to the control unit.
depending on the unit. mine is citroen.
take the red power cable an connect it to reversing light. (mine is yellow)
ground the yellow and black cable to the grounding bolt near backlight.
OEM Number
Park14 xG4B8101 Rev.00
OEM Number
