  • 3 Vote(s) - 2 Average
Headlights again!!!!
Greetings, all. 2003 2.0 HDi with 56k on the clock.
Been lurking and had success with the very few faults my 2003 Multispace has acquired over the years, thanks to all.
But this one beats me at present.
The offside headlight motor appears to have failed (first time it has needed any work for the MOT:brickwallSmile and before I splash out on a new one, with all that is involved with removing the bumper etc. is there an easy way to check if it is the motor as I don't have a wiring diagram to check myself?
I only ask as I often drive abroad and put the lights onto full "loaded" position to avoid dazzling other users and when my band is playing when the car is loaded with gear. Obviously I can use the manual adjuster to do so before I go anywhere, but it's a lot of hassle getting them aligned correctly again.
For the past 5/6 years, if I move my headlights adjuster on the dash from the very lowest position, both headlights start endlessly rolling up and down...up and down all by themselves, goes on for hours. People in the street have shouted..."Hey Pal, yer lights are wobbling up n down!!!". and on winter mornings at the security check at work they always remark on my cross-eyed Blingo lol
I leave them on the lowest setting and they dont move.
Didn't realise headlight motor was part of the MOT? Confusedcratch:
The headlight alignment/height was out due to the motor failing midway between upper and lower limits. Hence why it needed to be done for the MOT test.
So, yes, it is in theory if it puts the lights out.
Any ideas?
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
