  • 4 Vote(s) - 3 Average
Rear Light Upgrade
I have an 03 Berlingo with the smoked rear lights & was wanting to swap them for the later rear light clusters with clear lenses for a more modern look - Are they a straight swap or are the connectors etc different on the later MK2's ?
(17-08-2013, 10:16 AM)brandescot Wrote:  I have an 03 Berlingo with the smoked rear lights & was wanting to swap them for the later rear light clusters with clear lenses for a more modern look - Are they a straight swap or are the connectors etc different on the later MK2's ?
I want to do this too, they look cleaner & more modern/fresh imo. I had a quick search on here & it looks like they are a direct replacement although you have to get van lights for a van & multispace lights for a multispace because of the way the wiring goes in to the top of the light in respect to the vans having twin opening rears & the multispace having swing up & over. This is only what I have read on here & not my experience yet as I have not purchased the later lights. Will be my next 'mod' though..:thumbsup:
hi
yes they do fit ,i have the newer clear lense in my o4 blingo,takes couple mins to swap over ,very easy
[-] The following 1 user says Thank You to tommy1 for this post:
  • brandescot
Berlingo digital cluster speedometer upgrade
Last Post: kaktusas
Yesterday 02:48 PM
Cruise control retrofit
14-12-2025 09:37 PM
14-12-2025 01:33 PM
14-12-2025 12:49 PM
14-12-2025 12:00 PM
Anti Pollution fault warning
14-12-2025 11:39 AM
An almost Hydrolock in a DV6B
Last Post: chrisl
14-12-2025 09:36 AM
Last Post: chrisl
14-12-2025 09:27 AM
tyre pressure monitoring system (TPMS)
10-12-2025 07:50 AM
Wishbone Lower Control Arms Questions
09-12-2025 07:19 PM
