  • 28 Vote(s) - 3.46 Average
Engine Coolant
Sorry if this is dumb of me Confusedillyme:
Is there a specific type of Engine coolant for the Berlingo or can I use any? Noticed my coolant is below minimum earlier today
Thanks for any help
Lliam
70 plate Berlingo
I'd want to know why it's dropped too..
WHen re-doing my Berlingo after bypassing the matrix, I simply used a standard blue coolant at a 50/50 dilution
[-] The following 1 user says Thank You to Phil_G for this post:
  • lemsworld
To be safe, just make sure you top up with the same type.
There are two, blue and red. The red is allegedly better and longer lasting and also more expensive.
There's a theory that mixing the two is not a good idea as it reacts and goes all gloopy or something...
[-] The following 2 users say Thank You to tucker for this post:
  • Andre, lemsworld
I havnt checked it since I've owned it so not sure how long it has been low for and how quickly it has dropped. How do you tell which colour? I don't remember seeing a colour whilst I was looking at it
Thank you
Lliam
70 plate Berlingo
The red one looks more yellow coloured in the expansion tank.
Or you could drop the lot out and replace it all. I need to do mine as it only supoosedly has a 5 year lifespan and should be renewed. Mines been in there 7 years.
[-] The following 1 user says Thank You to tucker for this post:
  • lemsworld
Ive had my car nearly 2 years, god knows when it was last done. Maybe that may be the best option, I don't remember seeing blue at all maybe it is the red
Lliam
70 plate Berlingo
or maybe it's just full of muck! Get it flushed out and refilled with a good quality 50/50 mix mate. Cheap insurance, in my book...
[-] The following 2 users say Thank You to Phil_G for this post:
  • lemsworld, ron
There is a universal coolant available which you can use to top up any colour of original coolant.
[-] The following 1 user says Thank You to knobblywobbly for this post:
  • lemsworld
(15-05-2011, 07:43 PM)lemsworld Wrote:  Is there a specific type of Engine coolant for the Berlingo or can I use any? Noticed my coolant is below minimum earlier today
PSA recommends BASF Glyssantin G33
pk - Is this coolant red or blue?
Here are some photo's of the coolant tank
[Image: cffaa99c.jpg]
[Image: 63bf8d65.jpg]
From the look of these the coolant looks like the red to me as it looks yellow in colour
Lliam
70 plate Berlingo
Hello guys.
Today 01:34 PM
Touchscreen update
Yesterday 01:41 PM
10-07-2025 10:09 PM
Adding aircon oil after component replacement
Last Post: Ian_99
10-07-2025 08:10 PM
Spare key programming ?
10-07-2025 02:37 PM
Rear electric window regulators
Last Post: phydaux
09-07-2025 10:27 PM
Problem Passenger Electic Window
Last Post: pavb2
09-07-2025 06:49 PM
Solenoide, Wastegate
Last Post: BerlingoCitroen2011
09-07-2025 06:44 PM
New user
Last Post: nonce
09-07-2025 01:42 PM
Brake problems again!
08-07-2025 03:38 PM
