  • 2 Vote(s) - 4 Average
Rear brake shoes m59 berlingo
Hi iam a new member running a 2008 90bhp berlingo I just changed the front discs and pads no problem but how hard are the rear pads to change::O
Rear pads are easy to change, you undo the two 13mm securing bolts and take off the caliper.
You will need to wind back the piston of the caliper, clockwise.
Fit the new pads with a smidgen of lube, and then when finished, pump,the brake pedal before working the handbrake.
Sorry I ment the rear shoes, I bought I kit to day includes new cylinders but the nut for the brake line into the rear of the cylinder has now rounded off!!!!!!!!
Are the cylinders leaking or seized ? They are not usually included in a brake kit.
I replied to your other post about the same thing, best to keep only one thread going !
Let us know how you get on with heat for removal.
If you end up failing you'll either need a garage to sort it or have access to tools.
Coil pack for 1.4 petrol
Last Post: mikeyr
Yesterday 11:49 PM
THE ITALIAN BOX ?
Last Post: THE BADGE
Yesterday 09:29 PM
My new partner (well it’s the same van!)
Last Post: Trevor
Yesterday 09:17 PM
new vehicle
Last Post: Javier_432
Yesterday 08:56 PM
How Often Does AC Need Re-Gassing?
Last Post: hawaiianblue
Yesterday 06:44 PM
» Replies: 16
Peugeot partner 09 1.6hdi 75bhp
Last Post: dumdum
Yesterday 05:58 PM
Hi from the Midlands UK
Last Post: dumdum
Yesterday 04:57 PM
Lowering fun
Last Post: dumdum
Yesterday 04:54 PM
Full 1.9D Van Spares
Last Post: TONX
Yesterday 04:33 PM
Major investment time.
Last Post: malgpz900
Yesterday 12:04 PM
» Replies: 24
