22-08-2013, 06:26 PM
Hi all,
I'm having a small issue with my 2004 Berlingo Enterprise 1.9D 155k
On a run the temp is fine (around 70 or lower on the motorway) but if I leave it ticking over after this it will slowly rise up to 100+ (think the most was about 107) it will then go back down when driving. I am obviously concerened about a head gasket, but I can't see any major signs of that (no mixture of oil/water, no loss of power, cold/hot air blowing fine) it is however using a small amount of water (very small, I'm monitoring it)
I can't say I have heard the fan kick in.. I'm wondering if this is not working and causing the engine to run a bit hotter thus using a little water?
Any ideas? many thanks
Worzel
Worzel
