Threads: 20
Thanks Received: 3 in 3 posts
Thanks Given: 14
Woken up this morning at 4 by the alarm on the van going off. Wouldn't turn off on the key fob so I disconnected the battery. Found out this morning that the battery was flat. Put a bit of charge in it and started the van. Wipers were going despite being switched off, stopped the engine removed the key and they were still going? Any ideas?
Threads: 29
Thanks Given: 67
20
Poltergeist or demonic possession I'd say (
or possibly requires a BSI reset)
Threads: 20
Thanks Given: 14
ok, I think its the demonic possession. As soon as the battery is connected (no key in ignition) the dash starts flashing like a christmas tree & the side lights are permanently on, even with the switch off. I've attempted a BSI reset twice?
Threads: 67
Thanks Given: 1,045
Try stickytaping a clove of garlic to your ignition key.
When this doesn't work, replace the COMM control hub on the steering column.
Threads: 67
Thanks Given: 1,045
Two things fail more commonly then the BSI, assuming your BSI isn't wet inside.
The control hub - especially on M59 era models - went through a couple of design revisions to iron out weaknesses. The fuse panel under the bonnet ("BSM" as the Fleabay vendors call them) also can fail in a few ways, varying from no wipers at all (constant fuse blowing) to nonstart/run situations.
Threads: 20
Thanks Given: 14
Don't think so as the alarm could be disarmed after the battery was charged. Problem is wipers and side lights on permanently
Threads: 13
Thanks Received: 30 in 30 posts
Thanks Given: 6
Have you done the BSI reset procedure?
