alternator belt chirpping
Threads: 12
Thanks Received: 69 in 55 posts
Thanks Given: 7
my belt makes a chirping noise, not very loud, cant hear it from inside the van but can with the window open. ive fitted a new belt and it still does it, I find it annoying, my mate and brother are both mechanics and look after some pug hdi engined taxis and they say they all sound like it, ive listened to 3 others, 2 did it 1 didn't, has anybody else have this?, I might replace the tensioners to see if its one of those but when you wet the belt it doesn't make the noise, im wondering if its a characteristic of the set up with just belt to tensioner roller contact noise
Threads: 13
Thanks Received: 30 in 30 posts
Thanks Given: 6
well, mine didn't used to make any noise until fairly recently, now when I am in a hurry and drop the clutch followed by a heavy foot on the accelerator it momentarily chirps as it's under load, guess its a sign the belt tension needs adjusting or the belt replacing.
I've not looked but how do you adjust the tension on the aux belts on these cars? are you 110% yours is adjusted correctly?
Threads: 12
Thanks Given: 7
its properly adjusted, mine does it all the time. its not the noise when it slips a little just like a chirp/squeak kind of noise, to adjust mine you need a special long thin/flat like socket extension that releases the tensioner which is situated about half way down the side of the engine, theres two roller type wheels, its a pain to get to and took two of us to change as one needs to hold the tensioner as the other positions the belt
Threads: 29
Thanks Given: 67
20
Get some silicone spray, back to black cab cleaner works, and spray it on the belt while it's running. It quietens them down.
Threads: 12
Thanks Given: 7
still looking into this, changed belt, changed tensioners, tried wd40 gt85 silicon spray and talc and still some noise, been looking around on the internet, looks like it could be rust dust in cambelt, going to remove the cover and clean out soon as where I get. my van has been great then all of a sudden everything either rattles or squeaks, really starting to annoy me now
Threads: 12
Thanks Given: 7
update, it is the alternator belt, after spraying every liquid know to man on it (well almost) I tried some talc, sorted noise gone, the garage are going to fit a different brand of belt, continental this time to see if that helps
Threads: 50
Thanks Given: 743
(15-09-2013, 11:13 AM)finny Wrote: update, it is the alternator belt, after spraying every liquid know to man on it (well almost) I tried some talc, sorted noise gone, the garage are going to fit a different brand of belt, continental this time to see if that helps Oooh......I'll bet it smells luverly now too!! Glad you gotit fixed!
Hello guys.
Today 10:04 AM
Touchscreen update
11-07-2025 01:41 PM
10-07-2025 10:09 PM
Adding aircon oil after component replacement
Last Post: Ian_99
10-07-2025 08:10 PM
Spare key programming ?
10-07-2025 02:37 PM
Rear electric window regulators
Last Post: phydaux
09-07-2025 10:27 PM
Problem Passenger Electic Window
Last Post: pavb2
09-07-2025 06:49 PM
Solenoide, Wastegate
Last Post: BerlingoCitroen2011
09-07-2025 06:44 PM
New user
Last Post: nonce
09-07-2025 01:42 PM
Brake problems again!
08-07-2025 03:38 PM
