  • 2 Vote(s) - 2 Average
Permanent feed cigarette lighter
Evening all,
My cigarette lighter only works when my ignition is on but I'm sure it used to be able to be used when the ignition is off.
Could anybody confirm this, if so is there anything I can check.
Many thanks,
Gordon
What year is your car?
  • Gordon_Taylor
Morning Addo, it's a 1996
Easy one, then. On the fuse panel near your right knee, there's a couple of fuses - one at the very top, one at the bottom of the two parallel "tracks" of fuses, that can be hopped across half a space. One feeds the lighter, one the radio. Try pulling one to see which cuts the radio, so you can then reposition the other fuse.
The link below is for a Xantia but same principle - Fuses 1 and 16 can be moved one leg sideways:
http://www.frenchcarforum.co.uk/forum/vi...hp?t=27863
  • Gordon_Taylor
Weird, I took the bottom fuse out and found it was the lighter fuse and when I put it back I can now use the light socket without the ignition on.
Thanks for the info Addo.
Many thanks,
Gordon
I have the same problem. I have a 2009 Citroen Berlingo, is the job pretty much the same for my model?
[-] The following 1 user says Thank You to Silver Lady for this post:
  • Facom
(08-04-2019, 08:02 AM)Silver Lady Wrote:  I have the same problem. I have a 2009 Citroen Berlingo, is the job pretty much the same for my model?
2009 is a crossover year between models, Is it a B9 or M59. If you're not sure the easy way to tell will be searching for pictures.
Many thanks for helping.....I have the 'newer more modern shape'
It may be worth posting again in the B9 section.
Is this the same fix if you need a constant live for an aftermarket stereo?
Rattling calipers
Yesterday 05:36 PM
eolys
Last Post: magoo1
15-05-2026 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
