  • 6 Vote(s) - 3.5 Average
What bulkhead?
Got a 13 plate l2 lx berlingo van with twin side loading doors, it has 3 seats up front. It currently has a ladder rack bulkhead behind drivers seat and I want to fit a solid bulkhead with window. But the 3rd seat seatbelt loops through a bracket on the bulkhead and then fastens in the middle of the seats, is this a new design? None of the generic bulkhead makers ie vanguard have this bracket so it may have to be a genuine one, but what is the part no? Please help if you can?
I am getting the van plastic lined so need a bulkhead ASAP
Regards terry
ive got the 3 seat l1, the ladder rack stays where it is and the bulk head just fits behind
this might help, mine same as this http://www.ebay.co.uk/itm/Citroen-Berlin...19c65911bc but without the window
(28-08-2013, 04:03 PM)finny Wrote:  ive got the 3 seat l1, the ladder rack stays where it is and the bulk head just fits behind
Aah didn't realise that the ladder rack stays, was yours easy to fit? Does it use existing holes etc? Is yours twin sld's? If not does it kick back in by the door or is there a gap when door is open between bulkhead and seat? Sorry for all ?'s but want to get it right first time, thanks for your reply, regards terry
it bolted at the top through holes already there behind plastic caps, the side brackets I had to drill one small hole each side, the bottom I screwed into the ply lined flooring, ive only got one sliding door. if this makes sense "L" is seat <L, it sticks out in the middle. the bulkhead sits under an inch behind the ladder rack behind the drivers seat, it was pretty easy to fit on my own once it was in the back off the van, mine is steel so its not that light and its a bit cumbersome, with you having two doors it will be much easier to manouver
Today 10:41 AM
» Replies: 16
Today 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
24-10-2026 08:09 PM
