  • 4 Vote(s) - 1.75 Average
speed not working,
hi I need help with this problem
my clutch went on my and when it was repaired I had no speed clock working, the garage found nothing wrong, so auto elect did a number of checks and found all ok, he even used his laptop to bring up the speed on my clock to 70 to prove that the ecu was working, everything has been check on this car and I am going mad, the only thing I can think of is it happened when they put the new clutch in , anybody come across this before,
cheers
liam
If you have had your clutch replaced by a garage of some kind then they will of had both your drive shafts out to split the g/box. What happens is when they replace the offside one, they use too much force getting it back in which damages the the speed sensor's drive gears / pinions. This is a common fault.
Or - they might not have plugged the cable back in.
Either way - take it back and bang the table.
There's a few posts on this subject. Confusedalut:
.pdf   dw10 speed sensor.pdf (Size: 44.14 KB / Downloads: 27)
[-] The following 2 users say Thank You to Rustscrat for this post:
  • addo, brodfather11
hi
well thank god I am talking to a person who seems to know about this subject, I was going out of my head, when the auto elect showed me the speedo working from his laptop and he informed me all wires are ok, sensor checked out ok, I had a feeling it was inside the gearbox, armed from what you have just said I am going down to see them, will let you know what happens
thanks for lifting the pain in my head.
liam
[-] The following 2 users say Thank You to dingo1954 for this post:
  • Ol'Jeffers, Rustscrat
No worries - Let us know how you get on. :thumbsup:
service light(spanner) keeps coming on after res...
Last Post: Floki
Yesterday 09:23 PM
Power steering reservoir.
Yesterday 05:27 PM
My berlingo
Last Post: Madassmak
Yesterday 02:46 PM
13-09-2024 10:15 PM
» Replies: 41
What is this?
13-09-2024 07:23 PM
Iceland Trip and modifications
Last Post: Vantour Berlingo
13-09-2024 06:05 PM
Engine judder at 1800 rpm
Last Post: rodthemod
13-09-2024 04:58 PM
Heater blower not working
12-09-2024 12:22 PM
Key.... repaired... but how much for a New fob
Last Post: Gadgetman
12-09-2024 08:19 AM
Correct FAP Tank? 2012 plate L2 van
11-09-2024 11:34 AM
