  • 5 Vote(s) - 2.6 Average
Mk3 Xtr Fog lights.
Well I managed to buy what I thought was a absolute bargain on ebay last weekend, It was a complete Fog light Assembly from a Peugoet Partner Tepee for £59.99.
It now transpires that at some point they changed all the mounting for the fog lights from a single screw holding the foglight in to 3 screws holding the light in. The plugs are also different and the bulb is a mounted in the carrier for the peugoet fog light. Oh and the fog light units themselves are different as well.
So what I'm asking is are the later Berlingos with fog lights like this,
New shape light on left, Old on right.
Because I'm no better off what so ever because they are both different.
[-] The following 1 user says Thank You to Muppet1 for this post:
  • taxi
That's odd; the black one looks very much like an M59 foglight.
M59 being older Berlingos??
As you can see the fog light surround fits lovely as it should, Just wasn't bargaining on different Fog lights and different plugs.
Well its On the car and can stay like it is now, Looks a whole lot better for having the new 2nd hand bumper on and the fog light in the hole, Just need the chrome ring for the drivers side one now.
Mines an 09 xtr & it has the single screw fitted foglight on right in your first picture. Citroens want about £45 for them but ebay sellers have them for less than £20. I replaced a broken one on mine a couple of yrs ago with an ebay cheapie & its still ok..
Some versions had H1 and another H7 bulb in fog lights - maybe there is different.
Partner Tepee 1.6HDI 92@115bhp / 17"aloys / -35mm H&R kit / MyWay upgrade
[-] The following 1 user says Thank You to fazy for this post:
  • addo
newer models have 3 pin plug as it is fog light with "corner lighting". (facelift models)
Templ - do you know which models have the corner lighting ?
Or can it be enabled on any model ?
T1ny
(31-08-2013, 02:10 PM)Muppet1 Wrote:  Well I managed to buy what I thought was a absolute bargain on ebay last weekend, It was a complete Fog light Assembly from a Peugoet Partner Tepee for £59.99.
My XTR is a 2010 model with the YELLOW fogs like your picture is. My bulb on the passenger side has gone but i cant work out how to remove it to swap the bulbs out. Is it removed via the 10mm dia hole in the bottom of the bumper or do I have to go through the wheel arch somehow???
Do you have the handbook? bulb change described in there. You have to remove whole foglight to change bulb so same as for changing complete foglight. Use the long torx driver which should be in toolkit with wheel brace stored with jack under driver's seat. You have reach behind valance to get to back of foglight, pull off connector, then with torx driver & using torch, locate screw in bottom of foglight. Once screw is out, whole unit is removed from front & you can change bulb. After refitting, stick screw to driver with blutack to get it back in. Your hand will hurt afterwards.
Yesterday 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
