  • 8 Vote(s) - 2.13 Average
2004 berlingo rear torsion bar making a noise
Hi Everyone
I have looked on the net to find a answer and I'm struggling...
When driving down the road and I go over a bump or speed bump there is a load twang from the rear... I'm an electrician so I have checked the back incase it was my ladders but it wasn't!
Then I jacked the rear passenger side up by the sill.
And as I went up the rear torsion bar trailing arm didn't move then it would release and twang. And it would do this a few times while jacking the van up...
And the same when lowering ...
Help me I don't m ow what to try ..
Thanks in advanced
Try the spring,on the rear brake compensator. It was doing it on mine, greased it up, problem solved.
Hi
I've had a look at the spring has snapped ...
It makes this noise like the exhaust is banging when you drive it aswell.. ( but its not)
Does it sound like a cracking or creaking noise. Confusedcratch:
Try opening the back doors, stand on the edge and bounce.
You should be able to pin point the noise with someone's help. :thumbsup:
I've jumped on the back and nothing happened think Tomo I shall have another go.
But it just seemed like the torsion bar arm was stiff, and like it would try to move then all of a sudden release making the creaky sound
If the wheel suddenly releases/drops when you jack it up from the sill jack point it could be your swinging arm seizing up! Confusedillyme:
How do I repair this? If this is the case. I have sprayed some wd-40 earlier today .
If it is the swinging arm bearings then I would go for a recon'd back axle.
(worst case scenario). Sad
Have a read of this. :thumbsup:
http://www.berlingoforum.co.uk/showthread.php?tid=2996
Last Post: Desdinova
Yesterday 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
