  • 17 Vote(s) - 3.47 Average
Anyone down south need some 15" steel wheels + tyres?
found these on ebay while looking for some for myself, bit far in brighton!
http://cgi.ebay.co.uk/Full-set-OEM-wheel...802wt_1139
[-] The following 2 users say Thank You to steve valentine for this post:
  • Andre, ron
Theres always people askin for a set of these, so cheers for the heads up Steve :thumbsup:
I looked for ages for a set before having to buy new ones. Well worth grabbing if you are thinking of getting winter tyres later in the year.
If interested, check your offset and that of these wheels !
(19-05-2011, 07:21 AM)Coco Wrote:  If interested, check your offset and that of these wheels !
These wheels are a direct fit for a berlingo.
The only thing would be the tyre size. The ones in the listing are fitted with 195/65/15 whereas the Berlingo (mk2) standard tyre size for 15" wheels is 185/65/15.
So these tyres would be 10mm wider and 6.75mm taller, doubt it would make a difference?
Wish they were closer!
I don't think that it would make any noticeable difference. In theory, there could be an insurance issue if you fit a non-standard/approved size but a quick phone call would clear that up.
There are couriers on eBay who tend to quote around £30-£35 for a set on wheels with tyres. Might be worth it if the wheels are cheap enough?
Offset quoted for a 406 is 13-23. The steels I have are 18. There is very little clearance on the inside of the rear wheels, hence my advice to check the offset. As an example, the alloys that were a perfect fit on my Xantia would not go on the Berlingo - even though the offset quoted on certain websites for the two vehicles varies only by 3mm.
The part number for the mk2 Berlingo 15" steel wheels is 5401H7 which also shows up as a Peugeot 306 part, as well as Citroen C5 (and probably others as well). The Berlingo offset, as Coco says might cause issues. I have looked for a definitive list of wheels/tyres/offset sizes, but have seen conflicting numbers quoted which doesn't help.
Side Light Bulb Holder
Yesterday 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
