  • 4 Vote(s) - 1.75 Average
Dashboard centre removal
Does anyone know how to remove the sticky-out bit in the middle of the dashboard? The bit with the gear lever, window switches, cigarette lighter, hazard light and door lock switches?
The reason is one of the clips that holds the cigarette lighter into the dashboard has broken off. The effect of the break is that the lighter socket is now rather dicky and overheats if anything is plugged in. We have a set of heated seat covers. Last time we used them, the 12v plug melted. The overheating is due to the dicky connection - the wiring is capable of handling the 1amp the heaters draw.
I want to pull the whole middle unit out so I can wire in the heated seat covers and whilst I'm in there, wire in a lighter socket to be located in the cubby hole behind the stearing wheel (for powering GPS/ phone etc without trailing wires).
The Bus II: 2019 XL Flair 1.2
I know when Halfords fitted my parrot system it all came out, they charged 45.00 for fitting , but it took them over 3 hours to do job, glad it was fixed price, it took them ages to take center consol and cupboards out to get to wiring.
2010 artic silver VTR with EXTRAS.......Confusedunny:
There is a workshop manual to download on This forum. Cant find it now. But i think it was chapter in the manual on how to remove the dash. Cant recall where it is. But perhaps some one Else can.
Try this:-
http://www.berlingoforum.co.uk/showthread.php?tid=371
[-] The following 1 user says Thank You to ntm1275 for this post:
  • Guanajuato
Thanks. I knew it was on here somewhere, but I couldn't find it for the life of me. Added as a bookmark. Now to find the time to actually have a go!
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
